Bending metal strip end for the torque tube support, aileron pivot assembly and wing fold tube support. Unable to bend the landing gear support. The metal bender did not provide a good grip on the 7/16 " end of the metal strip. To think of another alternative. The metal end strip of the engine support and the stabilisor slot tab was filed to get the required curveture. A steel bushing tube of 1/2" OD x 3/8" ID x 1 1/2 for the engine support was also cut.To tack weld later.
