Re-aligment was done again to ensure the cockpit area is square by using the double right angle ruler, a string and a leveler. Three (3) pieces of steel tube are cut to attached both fuselage side at the front portion of the cockpit area. A notch was done for a fitting unfortunately one of the tube is shorter after notching. Cut another pieces and redo the fitting. All fitting need further trimming for a good fit. The problem was that the weld tack was blocking for a good and proper fitting. Another two (2) pieces of steel tube for the back portion was cut for a proper fitting. Both pieces fit nicely without hinderence of the tack weld.
