Finished installing the control arm from the pitch servo to the bellcrank. Also installed the SV-1 vents on the fusalage using fuel tank sealant and pop rivets. Boy that tank sealant is some goey stuff. It doesn't matter how many times you use the stuff, its still hard to work with
