Finished installing the fuselage conduit on the left side of the fuselage this morning. Not fun - my arms are torn up but at least it's done. Looks good too! It runs from behind the instrument panel, through the gear towers, through the center section and rear spar and then goes through the aft fuselage bulkheads to the back of the airplane. This will be where I run the aft position light, elevator trim cable, etc.
Here you can see the black conduit running under the floor on the left side (from this view).
Here is the conduit under the left console. I may have to move it around for the fuel lines.
Running through the left foot well compartment and under the aileron trim mechanism.
