CH650 in the high desert
Date:  5-21-2009
Number of Hours:  5.00
Brief Description:  Flap Constuction
I started on the wing specific section today. I first began with the flaps. This has been by far the easiest part of construction so far. It is a pretty simple step and the parts are easy to manipulate. I think this is primarily due to the thickness of the flap skins and that the skin is preformed (top, side and bottom). I did not install the flairlead material where the rod from the flap actualtor connects to the flap. I did locate these parts but I would like to see how the actualor rod actually connects to the flap before I install it. I can see that the first wing construction is going to take some time since you are actually constructing a lot of components on both wings at the same time (flaps, aileron, rear span, etc).
flap ribs
flap ribs
symetrical flaps, hinge and ribs
drill out and rivet
drill out and rivet
