I finished cutting the alieron trim tab area and installed the trim tab. I found the lay out a little challenging and noticed that the clearance of the ribs next to the hole fairly tight (at least on one side). I think this was due in part to the cut layout and the fact that the rib was just a hair off center. There should adequete clearance, it is just not exactly how I would like it to be.
