Installed the horizontal stabilizer skin. I had a little trouble aligning the pre-cut slots for the front mounts with the end of the rear spar and had to do a little trimming on the slots. I also had a bit of a challenge spraying the corrosion protection outside due to the wind and the sail area of the skin. Fortunatley I didn't kink the skin. Note to self: Use caution with the bigger skin pieces and try to paint in the morning to avoid those afternoon desert winds.
