Clecoed and riveted from intersection of VS-707 along the front spar towards the root. Then riveted VS-707 rib. Had to replace rivet #1, #3, and #4 on the left side because rivets bent over. Did a good job removing rivets and setting new ones. Adjusted the way i was holding bucking bar and and riveted right side without any problems. Then squeesed rivets on VS-704 root trib and and nose ribs. Forward rivet on the right side had to be replaced due to setting to the side, replaced it without any problems. Squeezed tip rib without any problems. Forward rivet on the left side will have to be squeezed with thin yoke because of the clearance. VS is now ready for inspection
