OLEKSANDR'S WEB SITE
Date:  3-16-2014
Number of Hours:  6.50
Manual Reference:  06-04
Brief Description:  Step 6-7 rear spar assembly/ribs
Finished fluting ribs. Clecoed all ribs and spar assembly together, everything lined up perfectly. Final drilled all rib connections with #30 reamer. Proceded to skin vertical stabilizer. It was very hard to go around nose rib and tip rib, and in doing so put a slight bend in the forward section of the tip rib but it wasn' t nothing serious. After I finished placing the skin i noticed that there were sligh bumps on the skin around nose tip, and at this point I re-read what they meant by radiusing nose rib. Manual said that you need tp form the rib so as not to force it in, thats where I realized that more work was needed on the nose rib. To make smooth transitions on the notches and the tips I used a piece of plywood in the vice and a small hammer. It took me about 3 hours to form nose rib and tip rib.At the end it was good fit without bumps at the tips.
Spar and rib assembly
Radiused Nose Rib
Radiused Nose Rib
Skinned Vertical Stabilizer
