OLEKSANDR'S WEB SITE
Date:  1-4-2015
Manual Reference:  08-04
Brief Description:  Step #4 Fabricating Cradles
Purchased Rockwell table saw from Canadian Tire, 1/2" plywood sheet 4'x4', and aluminum angle from home depot. Clecoed together HS905 and HS -904 ribs. Cut out 4 equal pieces of plywood, then marked and cut one out. Used that piece to make 3 other cradles. Cut 4 pieces of angle and screw those pieces to the plywood using sheetmetal screws.
Marked plywood
Marked plywood
Finished Cradle
Finished Cradle
