OLEKSANDR'S WEB SITE
Date:  12-24-2014
Number of Hours:  3.00
Manual Reference:  08-05
Brief Description:  Step #1 Clecoe and rivet Front Spar
Clecoed every hole on HS-00902-1 Front Spar, HS-00907-1 Doubler, and HS-00913 Front Spar Caps. Started rivetining using rivet squeezer, working from middle of the spar to the edge. Got very upset with AN470 die, because no matter what I did, it left circle on the factory head of the rivet. After riveting few rivets, decided to make some research about the issue. Found some regulation that says that as long as its not deep its Ok. Still I decided to stop and ordered new die from Avery tools. Will be waiting until it arrives.
Clecoed front spar
Clecoed front spar
