Bearhawk Patrol #42
Date:  9-11-2008
Number of Hours:  0.25
Brief Description:  Thoughts on options
Thoughts on options
Mandatory VFR Instrumentation/Equipment (FAR Part 91)
- Airspeed Indicator
- Altimeter
- Compass
- Tachometer
- Oil Pressure Gauge
- Oil Temperature Gauge
- Fuel Quantity Indicator (need not be an instrument)
- ELT
- Seat Belts
Required for operation
- Master Switch
- Ignition Switch
- Primer
- Throttle
- Mixture Control
- Carb Heat
- Fuel Shutoff
- Elevator Trim
- Voltage Meter
- Outside Air Vent
- Cabin Heat
- Fire Extinguisher
Stuff I defiantly want
- Garmin 396
- Slip/Skid Ball
- Radio
- Intercom
- PTT on sticks
Stuff still under consideration
- Transponder
- Rate of Climb Indicator
- Nav Lights
- Strobe Lights
- Beacon
- Landing Light
- Taxi Light
- Beacon Strobe
- Stall Horn or Lift Reserve Indicator
Stuff I have ruled out
- IFR Instrumentation
- Autopilot
- Tail Hook for Hand-Propping
- Accelerometer ("G" Meter)
- Cabin Lights
