Brief Description: Finished drilling the 38 remaining long center att
Finished drilling the 38 remaining long center attach angles. Found that I had drilled one side of the first 20 angles with 2 extra holes each. Should not be an issue as they are well spaced apart. Trimmed to size and drilled all main spar intercostals.
