Mandatory VFR Instrumentation/Equipment (FAR Part 91)
- Airspeed Indicator - Altimeter - Compass - Tachometer - Oil Pressure Gauge - Oil Temperature Gauge - Fuel Quantity Indicator (need not be an instrument) - ELT - Seat Belts
Required for operation
- Master Switch - Ignition Switch - Primer - Throttle - Mixture Control - Carb Heat - Fuel Shutoff - Elevator Trim - Voltage Meter - Outside Air Vent - Cabin Heat - Fire Extinguisher
Stuff I defiantly want
- Garmin 396 - Slip/Skid Ball - Radio - Intercom - PTT on sticks
