Date: 9-29-2016
Number of Hours: 1.50
Brief Description: Floor
I found the easiest way to get the floor shape right was to make a template from a cut up cardboard box. There was some shaping in the corners to go around the cluster joins as well as the forward attach point of the control column. Traced onto a sheet of .016" 2024-T3 aluminium which is then cut and drilled before tinnerman nuts and screws secure it to the welded tabs. Cut outs will be made for the rudder peal stubs shortly.
Cardboard
2024 aluminium
Copyright © 2001-2020 Matronics. All Rights Reserved. |
