Date: 8-23-2016
Number of Hours: 4.00
Brief Description: Wing mounts
The wing mount fittings have been pretty straight forward. Built to plans and made sure the 3/8" tubing is a perfect fit for each attachment at the wing root after being welded into the square tube. Easier to do now than when trying to mount the actual wings. I have loosely attached the mounts to the fuselage allowing them to rotate freely and will weld them permanently in place when attaching the wings proper.
Drill press
Parts
Welded loose
Copyright © 2001-2020 Matronics. All Rights Reserved. |
