Today was a day of catching up and cleaning up items that had been on the back burner for a while. I remade a few of the wing fittings before epoxying them permanently into place. The aileron hinge brass tubing was also epoxied in. Holes drilled for the horizontal stabilizer cable attach points and 1/4" aluminium tube reamed out to 3/16" with the drill. The tubing was cut to fit between the attach points on the gussets, JB Weld applied to secure them. Whilst drying I had threaded rod inserted to keep everything aligned until dried.
