Legal Eagle
Legal Eagle
Sanding
Got onto a great idea for sanding blocks using off the shelf sanding belts.
Here's a link.
http://www.instructables.com/id/Simple-Belt-Sander-Blocks/
Made mine even simpler by cutting and rounding 75mm x 35mm pine to the exact size of a snug fitting belt (457mm).
Ribs placed back in the jig for the final time whilst the trailing edges are all sanded to the exact same length then stacked 26 high.
Blocks
Sanding
Stacked
Legal Eagle Home
677
Assembly
Covering
Engine Mount
Flight Controls
Instruments
Introduction
Propeller
Weight and Balance
