Date: 1-4-2017
Number of Hours: 1.00
Brief Description: Inspection covers
The AS&S inspection cover (Part # 09-19300) is very light weight and the tabs riveted to the underside slide inside the wing behind the plastic ring and hold the contoured cover securely in place. I have started with one at the aileron hinge and fuel tank outlet on both wings. May add more at the strut and wing fittings.
Clip in place
Contoured cover
2 per wing
Copyright © 2001-2020 Matronics. All Rights Reserved. |
