Date: 10-24-2016
Number of Hours: 2.00
Brief Description: Shock Struts
Made the washer assembly to hold the springs from either end. Unsure what the AN part number is for the washer however the ID fits perfectly the 7/8" tube. Welded up nicely. My welding technique has improved as the build has progressed.
...unlike my ability to cut a slot in the 3/4" tube. I started by drilling holes at either end and then drilling smaller holes between as guides for the larger drill to go back over and through. It kind of became a mess when I used a 1mm cut-off disk to smooth the edges. The disk overran the end and cut into the tube. I will try again tomorrow.
Cad washer
Welded
Fail
Copyright © 2001-2020 Matronics. All Rights Reserved. |
