Date: 10-17-2016
Number of Hours: 2.00
Brief Description: Wing fittings and struts.
In preparation for levelling both wings I have set up the struts at 6' each and will trim them to size once the LE is outside and I can put on both wings. Just getting everything prepared so all I need do is concentrate on levelling and setting the dihedral which is way out of wack right now. It is great to see a wing hanging off the side.
Dihedral
From the tip
From the root
Copyright © 2001-2020 Matronics. All Rights Reserved. |
