Date: 9-27-2016
Number of Hours: 3.00
Brief Description: Control stick (cont)
The plans called for 3" pulley however I had a 2-1/2" one and went with it. Still plenty of radius for a smooth cable operation. The pulley bracket is made from a 1-1/8" x .035" 4130N tube with an integrated cable safety strap welded on which also supports the pulley. Ran string lines to check for alignment and places where I would need to attach cable fairleads to the fuselage. We have full and free movement of the control column.
2-1/2" pulley
Trial cable run
Position
Copyright © 2001-2020 Matronics. All Rights Reserved. |
