Date: 9-13-2016
Number of Hours: 1.00
Brief Description: Gear leg spacers
This is how I set the 7/8" long spacers onto the gear legs.
Drilled a 3/8" hole through the centre of the gear leg then checked the spacer for fit which has already been drilled out to 1/4". Cut the top of the gear leg off to then heat and round over the steel. Weld the spacer in place.
Drilled
Bent
Welded
Copyright © 2001-2020 Matronics. All Rights Reserved. |
