Date: 5-23-2016
Number of Hours: 5.00
Brief Description: Aileron spars
Spaced the gap 1/4" at both ends then measured and cut the aileron spar web from 1/8" plywood. 1-1/2 " lightening holes added between the ribs and reliefs cut for the hinge blocks. Epoxied the web in place on both wings and cut the 1/4" x 1/2" caps in readiness for tomorrow’s work. 5 hours seems quite a long time for cutting, sliding webs into place and adding epoxy resin. It is methodical work but none the less enjoyable.
1/4" spacers
Curing
Working 2 wings at once.
Copyright © 2001-2020 Matronics. All Rights Reserved. |
