Date: 5-21-2016
Number of Hours: 1.00
Brief Description: Epoxy end ribs
I epoxied 2 hinge blocks to 2 end ribs last night and found the blocks had moved slightly when checking this morning some 12 hours later. A sharp tap with the hammer and they broke free (along with some timber so I know the T88 is doing its job). Sanded smooth to remove the dried epoxy and then rough sanding again for a good gripping surface, this time as well as the elastic bands I also pushed some 1/4" bolts partially through to hold the correct position. After a few hours I will remove the bolts so they are not fully glued in and then allow things to cure for a full 24 hours. Ran a 1/4 drill through afterwards to clean out the holes and then lined them up with the plywood supports and outer hinge blocks. Clamped tightly and drilled right the way through.
Curing
Copyright © 2001-2020 Matronics. All Rights Reserved. |
