Date: 4-9-2016
Number of Hours: 1.00
Brief Description: Sanding
Got onto a great idea for sanding blocks using off the shelf sanding belts.
Here's a link.
http://www.instructables.com/id/Simple-Belt-Sander-Blocks/
Made mine even simpler by cutting and rounding 75mm x 35mm pine to the exact size of a snug fitting belt (457mm).
Ribs placed back in the jig for the final time whilst the trailing edges are all sanded to the exact same length then stacked 26 high.
Blocks
Sanding
Stacked
Copyright © 2001-2020 Matronics. All Rights Reserved. |
