SAM'S WEB SITE
Date: 4-16-2012
Number of Hours: 0.60
Brief Description: Torqued tank attach angle bolts
Only was able to do a little tonight until I get a rivet buddy and finish the top skin rivets. In the meantime, I torqued the bolts between the spar & the tank attach angles to 23 in. lbs, (20-25 per spec for AN3 bolts). Also fiddled with the Dynon autopilot roll servo a little, tighteneng and torquing some of the bolts, and safety wiring some in place. Leaving a few untightened until after the bottom skins are in place, since the servo and/or the linkage may make it difficult to buck some of the bottom skin rivets.
I used # 10 NAS Machine Screws on the inboard tank attach angle since the holes were a little close to the vertical leg, and the 5/16" heads could be torqued with a socket, while the 3/8" heads on the AN3 bolts could not. The NAS screw material is about 165,000 psi in tensile strength, which is a little higher than the AN3, so should be OK.
Tank attach angle to spar bolts torqued in place
The end attach angle, with NAS screws to the spar.
Servo with mounting bolts and rod end bolts torqued and safety wired.
