Pietenpol Air Camper
Date:  1-7-2018
Number of Hours:  3.00
Brief Description:  Cutting right aileron out
I cut the ribs and the wingtip bow and separated the aileron from the right wing. I cleaned and sanded the remaining parts. I re-installed the hinges. I tested for movement, everything proved to be ok. I tested the position of the control horn and pulleys. They work perfectly so far.
Aileron separated from right wing
Testing for control cables
Ditto
Ditto
