Pietenpol Air Camper
Fuselage bearings
I ground the angles on the bearing cylinders instead of filing. Easier and cleaner surface. I test fitted them on the jig and the 8mm rod was free to rotate. This means the holes are in allignment.
One bearing
The surface grinder
All of them
Gyrocopter Home
Pietenpol Air Camper Home
1016
Covering
78
Fittings
306
Instruments
Intro
Plumbing
411
