Matt & Val's 650B
Date:  12-26-2020
Number of Hours:  3.50
Brief Description:  wire harness in RH wing
I using woven nylon sleeve as a conduit for the RH wing wire harness. I'm using 3 conductor shielded 20g wire for both the position light and the landing / wig-wag lights.
grommets hold the harness going thru each rib, and adel clamps keep everything tight on each end.
both lights will ground to the same point on the outer spar
sleeve run thru grommets
holes for adel clamps and ground point
excess harness at wing root
