Brief Description: RH Leading edge and rib grommets
installed the #6 nutplates around the fuel sender opening in the LE skin
Changed from the rubber grommets to Nylon snap in bushings. I was worried about the rubber grommets degrading over time, and there was no access within the wing to change them out.
