The right wing tip did not fit the LE skin very well. the fiberglass tip was way inboard of the pre drilled holes. my solution was to make some relief cuts in the tip flange and pull it out into position.
once in position, i will reglass the flange and add some cabosil to build up the area with a skin gap
