Brief Description: Top Wing skin stiffeners between ribs
If you haven't yet purchased an edge marking tool...just do it already You don't need it, but it makes the process of marking center lines and rivet lines aa breeze
i removed the clecos from the trailing edge and peeled the skin up to locate the top skin stiffeners drilled all the holes #40, then will enlarge once all stiffeners are located
