Matt & Val's 650B
CH-650B
Checking 5th bearing runout.
5th bearing install kit has dial indicator to verify runout of bearing installed on crank.
High side was about .0009/ Low side was about .0006 = .0015 total runout
shims were a tight fit between bearing on crank and housing
low side runout
High side runout
shims in between bearings
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
