Matt & Val's 650B
CH-650B
Fitting crank and cam into case half
Oiled up the main bearings and set the cam and crank into position in the case half.
make sure timing marks are aligned and keys are in the proper position
crank, 5th bearing end
Crank, balancer end
Cam & crank meshed together
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
