Matt & Val's 650B
CH-650B
6-w
landing light & fuel tank
I riveted the landing light support structure to the nose rib.
put in about 3 gallons of fuel
I capped the ends and put a glove over the filler neck and pressurized with air.
I stood on end to make sure the fuel covered the sender, to check it's seal.
I'll check it tomorrow for leaks
Landing light frame attached
Fuel tank pressure test
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
