Matt & Val's 650B
CH-650B
6-w
Aileron Control rod
I put the control rod together and torqued the rod end on the bell crank
THe rest will most likely need to be trimmed when the aileron is installed and rigged.
I used some pipe insulation to protect the cables and ribs from grinding on each other being moved around the shop.
I have a "rigging" block stuck in between the rib and belcrank. it will keep everything centered while the cables are tightened.
All bundled up
Cable protectors
Contrtol rod installed
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
