Matt & Val's 650B
Date:  1-23-2021
Number of Hours:  2.50
Manual Reference:  6-w-10
Brief Description:  RH Leading edge and rib grommets
installed the #6 nutplates around the fuel sender opening in the LE skin
Changed from the rubber grommets to Nylon snap in bushings. I was worried about the rubber grommets degrading over time, and there was no access within the wing to change them out.
THe nylon grommets will not degrade over time
Nutplates around sender
Nylon grommets
Nylon grommets
