Matt & Val's 650B
CH-650B
6-w-10
fitting right tank into LE bay area
it's a bit of trial and error to pit the tank in and out of the LE bay. It's hard to get the drain hols cut in a perfect position as the welded in drain tube is at an angle
first time dropped in
outboard vent hole drilled
checking gap for cork on ends
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
