Matt & Val's 650B
CH-650B
6-w-10
fitting SW fuel sender in right tank
checking trimmed and bent float rod on my mocked up jig
i drilled a 57mm hole and added a small notch to the clamp ring to be able to fit it in the smaller hole
the smaller the hole, the more surface area available to seal to prevent leaks
float on bottom stop
float at upper stop
checking clamp ring fit
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
