Brief Description: Fitting the oil filler neck to Valve cover
Corvair conversion requires moving the oil filler neck from the stock location to the R/H valve cover I got a few pictures as examples from W.W. on the orientation of the neck.
Once I got the neck ground to fit the corner of the valve cover, I tacket it in place.
After TIG welding, I cutout the corner of the valve cover and deburred all the internal edges
