Matt & Val's 650B
CH-650B
Engine Teardown / remove cylinders
I left the bellhousing on because it provided a stable base to stand the engine on its nose.
rotate crank as needed to access the rod nuts. gently tap to seperate and pull the cylinder-piston-rod out of the case.
a small head ratchet or breaker bar is needed to get in between the throws of the crank and the internal case supports.
case on bell housing
Cylinders removed
Back yard visitor
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
