Brief Description: tie down support and access panel
with the tiedown cleco'd to the rib, it was very flexible
I created an L bracket from .050 and attached it through the existing holes in the spar and rib. plus a few extra holes to spread the load.
i dimpled the access panel because it was too thin to countersink. The nutplates supplied in the kit are not dimpled, but will still work for an access panel
