Matt & Val's 650B
CH-650B
6W-3
Fitting all the nose ribs
Started with nose rib#9 and worked my way inboard
Some of the spar angles needed trimming to be below the contour of the rib.
had to trim rib #1 to fit over the root doubler and make sure it was in line with 2 and 3
Nose ribs 4-7
Need to trim spar angles
Aligning nose ribs 1-3
CH-650B Home
228
Elevator
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
Work benches
Work benchs
Workshop
