Matt & Val's 650B
CH-650B
6-W-3
Wing ribs
if you don't have a 90 deg drill, a 12" drill bit can be a possible substitute.
the length and flexibility allow you to get the drill moter / chuck far enough away and still be able to drill a straight hole up close to the flange.
laying out nose ribs in order
12" drill bit, instead of 90*
using long drill bit
Starting nose ribs
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
