Matt & Val's 650B
CH-650B
6W6-xR
Wing Rib lay out on spar
Started fitting the rear ribs to the front spar
Marked rivet linea and drilled thru factory holes
Ribs 1&6 needed the top notch cut. Some ribs need hammered on the ends to fit/match the spar
Lay out Ribs in order
Mark rivet lines on Spar
Rivet lines on Ribs
CH-650B Home
450
Electrical / Lights
Elevator
84
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
197
Work benches
Work benchs
Workshop
