Matt & Val's 650B
CH-650B
6W6-11
Aileron bell crank support
Match drilled the supports, then rough cut on the band saw. Cleaned up edges on sander
Made spacer block from plywood and scrap sheet metal to set gap between supports when clecoing to RR#7 and 6W6-10
Removed spacer block and inserted belcrank assy to verify everything is tight, but moves freely
Drilled and rough cut 6W6-11
Verifying spacer block thickness
drill / cleco & test fit
CH-650B Home
228
Elevator
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
Work benches
Work benchs
Workshop
