Matt & Val's 650B
CH-650B
6-W-2
Right Aileron
Set up rails with 13mm block per photo assembly guide / plans
installed ribs, drilled and clecod bottom skin and located control horn on inboard rib
Setting twist in skin, 13mm
Bottom side skin clecod
Aileron horn located on inboard rib
CH-650B Home
228
Elevator
Flaps / Ailerons
Horizontal Stabalize
Kit Receipt / invent
Rudder Workshop
Work benches
Work benchs
Workshop
