Matt & Val's 650B
Date:  2-9-2020
Number of Hours:  1.00
Manual Reference:  6-W-5
Brief Description:  Attatching spar tip
When I butted the spar tib against the end of the caps, it was angled up, so I clamped "L" brackets to each side of the spar to keep it aligned while I drilled the holes.
Layed out the l angle on the end
Get all nose ribs in position.
All rib flanges point outboard except for NR#3, it faces inboard
Attatching Spar Tip
Attatching Spar Tip
L angle on Tip rib
L angle on Tip rib
Getting Nose ribs in position
