Drilled the shoulder harness anchors to the longerons. Drilled the static source holes. People on the RV-10 list seem to think the Vans static source kit is kind of cheesy being based on a rivet in this hole. There are other kits out there I will probably go with when I get to that point.
Final drilled the attachment holes for the side skin cover plates as well as the nutplate rivet attach holes for the cover plate nutplates.
